Hikerdogs
Jan 14, 2017Explorer
On our 2001 Adventurer the plate cracked around the bolts that hold the stairs in place. I removed the stairs (4 nuts and 2 wire connectors. I then pounded the plate back to the original position and welded the cracks.
I then cut a piece of 7 gauge sheet metal the exact size of the original support plate. I drilled clearance holes for the bolts and welded it in place under the original plate.
As I recall the repair was made in 2008. It was still holding fine wen we traded off the motorhome in 2013 with over 100,000 miles on the odometer.
