tropical36
Jan 14, 2017Explorer II
bamaman3 wrote:
How do I fix sagging steps on a Suncruiser motorhome? The outside bolts have pulled the metal plate down and the steps give when they are used.
Had an old coach once with the problem and there was just no way to bolt it back up properly, like the way it was, so ended up with a metal strap to go across the underside and for bolting it to some framework. Made it so that the more I tightened the bolts, the tighter it pulled up on the step assembly.
