atsrmf
Apr 29, 2018Explorer
I would never buy the motor online again. You need to be able to compare the old with the new. I doubt anything is available that is a drop-in replacement without some kind of modification to the mounting bracket. You may have to re-use the worm drive assembly which doesn't wear out normally. Be careful when removing the drive, as the brush plate can come loose. Getting it back into place is difficult, the springs need to be retracted fully so the brush can go back in. Latch the spring on the mount bracket temporarily.
