rgatijnet1 wrote:
fourmat wrote:
I believe that wire on mine powers the lights under the step when deployed if I put the lock out on on the step lights go out
Mine has a little "hockey puck" size light that the wire goes to. This light is ONLY illuminated when the steps extend and retract in the auto mode. When the steps are extended, and shut off to remain extended when parked, that light is off.
Correct. That "wire" in question is for the little "under step light" as Kwikee refers to it, and not to connect to the main, outside "porch light".
You may find out what you need to know from their website. There is a lot of useful information there...
PowergearUS-Kwikwee
