beaubeau
Sep 20, 2017Explorer
Kwikee steps again
My Kwikee steps (on a 2008 Allegro) failed a few weeks ago -- they will not extend.
Sorry for the long post but I think the details may be important, but if you want to jump ahead - my question is "How do I actually get the wires from the battery into that tiny plug on the motor without risking a short?"
I kinda feel like it's an electrical problem since they never ave reliably retracted, and would sometimes extend even when driving.
But ... now they are stuck in the retracted state.
I ordered the diagnostic 4-way pigtail for the steps and started the troubleshooting found on page 7 here: https://www.lci1.com/assets/content/support/manuals/pg_875.pdf
I got to this step:
7. To extend the step, touch the white wire to the battery's positive (+) post. The step should extend and remain extended.
So then I proceeded to :
10. If any of the step functions do not work, the source of the malfunction is either in the control unit and/or the motor. Proceed to the "Testing the Motor" section.
Which gets me here:....
11. Disconnect the two-way connector between the step motor and the control unit.
Connect the motor’s red wire to the positive (+) terminal of the battery and touch the motor’s yellow wire to the negative (_) terminal of the battery to extend the step. To retract the step, reverse the connections. If the step extends and retracts during this test, the condition of the step motor is good.
NOTE: On steps with control unit #909507000 reverse the red and yellow wire connections to perform the afore- mentioned test.
So here is my question -- How do I actually get the wires from the battery into that tiny plug on the motor without risking a short?
I got to this step:
