J-RoosterExplorerAug 16, 2016Kwikee StepsWhat do I need to look for to get my Kwikee Steps to work properly? When the engine is running my Kwikee Steps work just fine! When the engine is shut off my Kwikee Steps will not extend (they stay in...Show More
BelgiqueExplorerAug 17, 2016Mine was doing this. If I pushed the battery boost switch they would work. Most likely culprit is a bad ground connection. Good luck!
