Iam in Hot Springs Ar......with a a badly missing 460....My scanner shows nothing .....Iam looking for recommendations for a shop to scan my engine beside Riser ford....I cannot leave my MH a few days...
Today I limped about 8 miles to a RVpark....and ordered a reman pcm from a Ford computer place on line as no one else has them....cost $380 and they will put my program in it according to the info on my pcm and my VIN. I will get it in two days and its plug and play .The dealership pulled the code from my memory ....shorted sprout circuit grounding my coil.......should work good. PCM is located behind the steering column ..on the firewall. an extremely hot place most likely that's the cause.
