Chuck_Sorensen
Dec 11, 2014Explorer
Larger Diameter Tires - Odometer / Speedometer
When we bought our van, its stock tires resulted in the speedometer reading high. After replacing the tires with the next size larger tire, the speed indication was dead on. I assumed that the odometer was then accurate along with the resulting MPG calculations from the Ford computer.
Later I observed that the Ford odometer mileage to one of my 100 mile auto club towing radius points was 5% short. I verified the my decades old 100 mile point was still correct using two on-line road trip sites.
Using the 5% odometer correction, the Ford V-8 gas mileage now moves up to an overall 14 MPG. But only if the fuel measuring system and Ford computer calculations are correct.
I wanted to know the gas mileage of my first vehicle, a 1953 Chevy pick-up. I filled a one gallon gas can and carried it in the truck’s bed until I ran out of gas. Then, after noting the mileage on the odometer, I put the gallon of gas into the truck. Using the truck until it ran out of gas, including refilling the gas can, the odometer reading let me calculate the MPG. Even at 23 cents per gallon for gas, economics prevented a full gas tank.
This is another example of marvelous teenage thinking. Like using a hot soldering iron to melt tread into bald tires.
Chuck Sorensen
Buellton, California
2012 PW Excel TS
Chuck Sorensen
2012 PW Excel TS
