nomad_289
Jan 08, 2014Explorer
I got the Lazy Daze 26.5' mid-bath. Conceptually an efficient use of space, with two separate living areas in a compact space.
58 gal fresh, CAT scale 3K OCCC. (11K lbs w/gas and propane)
OCCC vs CCC
OCCC is computed as follows: OCCC = GVWR - (UVW + Propane)
CCC = GVWR - (UVW + Water + Propane + SCWR)
SCWR = # sleeping positions x 154 lbs
Rear bumper 4K towing, 400 lbs vertical weight. "weak" bumper mounting
Best idea already mentioned is a front hitch.
I put 10K miles on my LD this year...great unit, you won't be disappointed unless you're doing cold weather camping. Fully loaded with water, food, tools, 2 passengers etc. unit weighs 13K, (~1000 lbs to spare).
Found mine with Google search "Lazy Daze for sale". Was listed on an obscure RV site. Oodle is also very good. Good luck.
OCCC vs CCC
