Georgia Popcorn wrote:
DOUG IN TEXAS,
WHAT IS IT THAT I HAVE TO LEARN?
My signature says I have a 2017 Hurricane 29M motorhome
You may need to "learn " again.
1. This thread is about LCI HYD jacks on a motorhome.
2. Your sig shows a 5th wheel. Which should indicate you have the Electric GROUND CONTROL LCI system. Please confirm if this is right
3. The reason is, IF you have Ground Control, there is NO RF sensors at all. LCI Ground Control, is ALL hardwired.
4. Please state the Brand and Model of your level system. Doug
You show a Keystone Outback. I did not scroll down further and see the Hurricane. What YOU have to learn is simple. NOT ALL JACK SYSTEMS ARE THE SAME OR OPERATE THE SAME, EVEN THE SAME BRAND JACK(there are lots of models). So, like I asked, What MODEL LCI system do you have? I have worked on almost ALL jack system for the past 30 years and have never seen a RF signal style system. But, LCI is always coming up with new systems that are only for certain OEM's. That is why I want to know YOUR model of LCI. Doug
