Well I have a hole in one of my lippert leveling jack hoses. So all the hoses have the plastic jacket falling off them so I though maybe I would do the back 4 lines now and the front 4 later. Well may...
While LCI does make and supply Hyd lines for their Hydraulic systems, some OEM's use aftermarket hoses which are a lot cheaper than LCI hoses. So, unless you can verify your defective hoses are LCI, don't be too quick to condemn them. The aftermarket hoses used on LCI systems do bubble and leak from inherent weakness's. USUALLY after the warranty period. Doug
