lakebum's avatar
lakebum
LCI Leveler Wiring Diagram?
Does anyone have a wiring diagram for a LCI Level/slide? I had a hydraulic motor go bad and had to replace it, no problem, but found out it also shorted out the solenoid which I replaced, no problem. But there is no 12v power feeding the solenoid, so I tracked the hot wire back to the ignition switch relay. However, there is no power on the entire ignition side of the fuse box and I cannot find how it is fed.
Not sure if I need to contact LCI or Coachmen for help. Seems like I should be able to find the entire circuit.
1 Reply
  • Need to call coachman. They use to have some electrical on their website.
    Is the relay energizing? Check the battery side of the ignition relay for power.
    If no power trace it back toward battery. Blown fuse.
    If yes, trace the control circuit.
    Likely it is blown fuse for power circuit.
