ct1964ups wrote:
ROYBUCK wrote:
I posted on here about a month ago about my leak. A forum member suggested raising one side of the MH which I did and it stopped the leak. I went in a minute ago to check it out since we have had some rain, it was not wet but when I moved the slide out then back in it was wet where it was before Now this is not clear water it is a brown looking color like a rot wood or rust color, also as I stated it looked like the water was coming from the inside of the slide (the enclosed section) it is on the front right hand corner it you are standing at the foot of the bed. Planning on taking it in to a service center as soon as it warms up a bit. Does any one have any suggestions as to where the leak is coming from. Want to put up for sale but every time I get ready something else pops up. Sorry about long thread. Thanks Roy
Camping World sells a roof sealant....forget the name right now..but comes in clear or white in Qts or gallon size......can put in on with a old brush or trowel..thick but brush works well.....i do the roof of all my RV's over the yrs and had 8 total.....BUT,I don't do the whole roof.....I use a brush and do all the seams and all the spots that have screws....wipe with a rag as I go..look for rust spots and any flaking....and then just check rest of the roof for any cracks and cover if see a spot that might leak.....It took me a Qt to do a 41 ft motorhome......
I did this to all my RV's every 2-3 years ......Chuck
Chuck
Don't know if this is the stuff you are talking about, but this works great. Had a bad bedroom slide leak did all seams the used a 2" roller under the topper, takes about a day to dry.
http://www.campingworld.com/shopping/item/proflex-brushable-sealant/21208
JR
