SCADAMAN29325
Apr 05, 2023Explorer II
All good stuff above, but I have found 2 problems.
1- regulator to tank connector was loose! I had found it loose before and retightened (hand tight). This time I moved the "c" ring and moved the plastic hand wheel out of the way so I could get to the nut and put a wrench on it.
2- Ordered one of those gas sniffers and been hunting the leak. That took a while: turned gas on, went round and round, inside and out for over an hour, nothing! Left the gas on for 2 more hours... tester went off like a rocket inside the furnace housing outside after removing the cover! Went inside to confirm the furnace was off, it was.
Now I need to figure out how to test the furnace system. I want to make sure the thermostat is actually turning off the furnace and it is not a bad thermostat. Then check to make sure the valve is closing the way it should (I think this will be the problem).
STILL, I don't see how the furnace valve being stuck open would cause the propane alarm to go off when going 60mph down the highway. Scratch that, 10mph start/stop traffic congestion.
It has gone off 3 times, once the last night of a week long camp in February, next in that start/stop traffic, then most recently when having the fridge cooling down the day before leaving for a short boondocking experiment.
So this where I am now, troubleshooting the furnace system.
TTYL, Phil
TTYL, Phil
38,782 PostsLatest Activity: Aug 31, 2026
