SCADAMAN29325
Aug 31, 2023Explorer II
Too Long, Don't Read?
I think I need to replace the propane valves on the water heater AND the furnace. The propane sniffer is going off near the burners of both appliances!
Update:
April
I took it to the service guy to replace the gas valve, but he found a loose fitting and tightened it up. (Yeah, it was loose because I couldn't get it out without buying more tools).
When I got it home everything was fine. Saturday, the next morning the LP alarm was going off again. Called the dealer, service desk said to check battery voltage, it may alarm on low voltage. Checked it, 12.4. Called back and told them to put a note on record about this and I will get it taken care of after we get back from our trip.
Fast fwd to August (it felt like we were camping every other week for 3 months! It wasn't that often, but felt like it. We took two groups of grandkids with us several trips. That was fun.)
The beginning of Aug I was going to test the propane again. When I turned on the propane I could feel it hissing out from around the valve stem. ****, so we took it to the shop to replace the valve on the propane tank. 2 days later they called and said it was ready and that it wasn't the valve, just a loose connection at the POL fitting. (I should have caught that myself!) Go it home, turned on the propane and it was still hissing around the POL valve! I took the regulator off to check it out. The o-ring looked chewed up, so I went to Ace Hardware to get a new one. BTW, it was 5/8 x 7/16 x 3/32, bought 2.
Now let's test again. Turned on propane, 24hrs later, no alarm, the next day it was alarming again! Broke out the propane sniffer, NOTHING. Could not get it sniff anything. MAYBE it wasn't sensitive enough. Checked the specs, should alarm at 50ppm. Checked the detector, it was saying 17x100ppm, 1700ppm. The sniffer should be going off! Hmmm, took it outside the sniff around the tank, nothing. But it did go off in the water heater burn tunnel. (Same as the furnace when all this started!) ALSO, when we do use the water heater on propane, everytime it lights there is a small explosion like a pop-whoosh-burn, but that may be normal, OR it could be that the burn tunnel is full of propane and the explosion may be larger than it should. (Again, same as the furnace.)
Right now I've moved onto other items on the todo list. I think I'm going to make sure the propane is off (it is now) clear out any propane from inside the water heater and furnace and start testing again.
There is a leak somewhere and I need to find it and fix it so we can use the furnace in a few months when it turns cold.
Still having fun with the camper!
TTYL, Phil
Update:
April
TTYL, Phil
38,782 PostsLatest Activity: Aug 31, 2026
