j-d
Jul 26, 2016Explorer II
Welcome Aboard!
Best thing is to have it pressure tested, or get a furnace blower and make a pressure tester. Then, soapy solution sprayed from and old 409 bottle will reveal the source. From the inside, you see where the water WENT and what you need is where it entered.
Do you have a Front Window? If so, Suspect Number One.
Suspect Number Two, Clearance Lights
Suspect Number Three, Clogged Track Drain Holes in Cabover Side Windows
From there, Suspect Pool (no pun...) is any Seam, any Sealant, any Damage
