ksg5000
Jul 28, 2016Explorer II
Have the rig pressure tested to ascertain where the leak (leaks) are coming from - cost less than $200 and will save you lots of time/money/aggravation trying to find the various sources of the leaks. Once the leaks are fixed - focus on what water damage has been done to the rig. There is likely a seam under the overhang where the water is dripping - remove the screws and allow all the water to drip out. Chances are you have water damage to the overhang - use Google and find the many threads where people have re-built the overhang - you may not need a total rebuild but chances are you have some damage that needs fixing. If your not handy - could be expensive.
