Cousin_Eddie93
Feb 25, 2016Explorer
Had leaks on my older C when purchased. The water never actually leaked from the Windows or their frame seal. The source of the leak was on the roof, the seam between the aluminum cabover and rubber Epdm roof. Some screws had nearly completely rotted away below the heads. The butyl tape had deteriorated and the visible damage was a good two feet away from the actual leak. The walls were fine. Water made its way down inside the alminum cabover skin. Just goes to show how weird leaks can be. Fix asap.
