Cras108erExplorerMay 22, 2017Leaking Fitting on 1998 BounderI have a 1998 Bounder with a water leak from one of the fittings. It appears the leak is coming from a fitting that is wedged between the gray water tank and the basement wall. Its almost impossible...Show More
Related ContentNautilus P1 has leaking connections1995 Bounder Fuel (gas) leakBounder ConstructionLippert faucet leaks, replaced with MoenWater tank fitting leaking
