rgatijnet1
Jan 29, 2015Explorer III
If you have the metal valve stems, there is a rubber gasket that can leak if pushed a certain way. If the rubber has hardened, the gasket may leak at certain times and may seal fine at other times. You also may have the valve core that has corroded from moisture inside the tire.
38,778 PostsLatest Activity: Jun 10, 2026
