jamesinkster
Mar 05, 2017Explorer
Leak Finding: Northern Lite
Hi guys,
I have an old (mid 90s) 9'6" northern lite. It's seen a lot of use over the years, and is getting a bit cranky.
I've spent the past while trying to track down a very small leak that shows itself as a drip below the passenger side main window. I've ripped off the inside wall covering to expose the insulation and the drip is right about the same location as the \__ of the side clamshell.
That said, I also understand how water can move about in these things...
I've removed and reinstalled the window, removed the clamshell trim etc in that area and reapplied it, etc, to no avail.
Worse, we're just returning from a big ski trip and I discovered another leak higher up on that side by the front corner of the camper.
I'm at my wit's end, and feel ready to completely remove the entire clamshell trim around the entire camper and attempt to re-seal it all.
First though... Is there some way to get a camper like this "leak tested" so I can figure out exactly where the water is actually getting in? It'd be a shame if I tackled a big job only to discover it was all for nothing.
Next, can anyone explain how that clamshell design works? Does there need to be flexibility between the top half of the shell and the bottom half? If it can be rigid, I'm at the point where I'd consider completely removing all the clamshell trim (white metal and black rubber) and glassing (or epoxying) a seam across the two halves, forever sealing the unit.
I suspect this isn't a valid option, though.
Any other tips appreciated...
