willald
Jan 31, 2015Explorer II
garry1p wrote:
Same problem many years ago really slow leak.
Finally after messing with it over a period of weeks removed tire from rim and there was the tip of a screw you could only find from the inside. Never did make bubbles even submerged.
Tech found it running his hand around inside the tire until he felt the sharp point only then could you see it.
Thanks for the advice, you're actually the 2nd person thats mentioned a slow leak, that was caused by something in the tire that could only be found from the inside. Definitely, on Monday, when I take it to a tire shop, will have them dismount the tire and look for anything sticking through on the inside.
Will
38,778 PostsLatest Activity: Jun 10, 2026
