willald
Feb 02, 2015Explorer II
Adirondacker wrote:
I was wondering if you ever tried to remove and reseat the inner spring-loaded pin from inside the valve stem.
Sometimes a little dirt or gum gets wedged in there while filling up the tires. By using a valve stem tool, you can unscrew the inner workings of the valve stem, view it, resecure it tightly, and refill it.
It has happened to me a few times on different car and bicycle tires. A three dollar valve stem tool saved me several times... You simply insert it into the stem and unscrew the spring loaded pin valve mechanism. Clean it up and re install it..
Any of the autoparts chains or Walmart will have them.
Edit: here is a Video Clip for the tool.
Thanks for the info there, good stuff to know. Will keep that in mind.
When they were checking with soap water, they poured some all around the valve stem, some inside, around the pin/valve inside as well. Was no evidence of air (bubbles) coming from there, but I guess it could be such a gradual leak through the valve stem, that it wouldn't show bubbles?
Well, I dropped the tire off at a truck tire shop this morning, and left it with them. Will see what they find. If they call and say no dice, just may ask them to go ahead and put a new valve stem core in, see if that solves it.
Will
38,778 PostsLatest Activity: Jun 10, 2026
