willald
Dec 22, 2015Explorer II
aeejbe wrote:
This post is few months LATE on this thread. But interesting reading because recently I had to deal with an elusive leak from one of my tires... ... ...Or so I thought.
Found myself blaming the tire, & then blaming a defective(?) Borg Valve Stem, & then seriously hating on the tire repair shop for not trying hard enough to find the problem.
Turned out to be the damaged WHEEL that was the culprit. A tiny break in the weld seam caused by TOO MANY BAD POTHOLES along a certain stretch of interstate road in a certain other state. (Oh yeah. I remembered it well). Just another case of my tax dollars NOT working hard enough – soon enough! In my case, the cost of a new wheel was actually less than paying for a new tire.
And btw IF it’s not too late, & you’re still bent on getting more service from that tire they say is un-repairable... ... ...
Go "the old school route" & put an inner tube inside, & keep it rolling as a spare!
Wow, yes, a bit late on this one. :)
New tire last March fixed this problem (although was a very expensive fix!) Have watched the tire pressures very closely all year, leaking stopped after replacing the tire.
I kept the old tire for several weeks, hoping to find someone that would repair it so I could keep it as a spare. Took it to at least a half dozen different tire places, asking if they would repair it. All said same thing - no way, cut is too close to the sidewall. Sooo, eventually disposed of it, its long gone now.
Hadn't thought about putting an innner tube inside it so it could be used as a spare. Its all 'water under the bridge' now, but can you even get an inner tube that would fit, work for this size tire? I wouldnt think you could, given that they havent used inner tubes on this kind of tire in the last what, 30 years or so?
38,778 PostsLatest Activity: Jun 10, 2026
