steppinstone's avatar
steppinstone
Leaking intake manifold
Hello I have a 1988 gulfstream sunvista hi rise on a john deere chassis with a 460 ford motor. Over this past spring while on a trip I found the oil was leaking from the rear and front of the intake manifold. I have purchased all new gasket's and was going to repair while laid up for the winter. The question I have is CAN anti freeze get into the oil from the intake? The reason I ask is I just started the coach to charge battery's and it seemed to be smoking a little bit more then normal so I shut it down and checked the oil and found it milky. Could it be the head gasket? I did over heat the coach on the trip the radiator hose blow out I fixed it on the road topped it all off no anti freeze leak's just oil as stated .Made it back home and just been sitting sense. I am hoping it's just the intake and not the head's..... any help??
