One of my POWERGEAR jacks was leaking last November. Contacting POWERGEAR, they refuse to sell ME ANYTHING. Must go thru a retailer or RV dealer. The leaking jack, an older model,according to the PG website was not "rebuildable"..having no repair kit.So....grit my teeth (stil have 'em) and spent over 600 bucks for a new one....this new model does have a "repair kit". Whoopie! However, repair kit or not, any imperfection on the chrome piston (nick, scratch...anything that would tear up the insides causing the leak) makes any repair not worth it. Plus....finding a shop to even attempt it is just about impossible. And you would be charged a hefty fee to have them tear the thing down, inspect it and tell you they can't do it.
Taking the old jack off (my 13 year old coach)....I needed a 200 psi air compressor and a Snap-On impact gun. (My Harbor Freight impact gun and 125 psi 7 gallon compressor was simply not up to the job.) Even then, I had to grind off the head of one of the 6 bolts. The hydraulic hose came off without a problem. Now...the bolts (and nuts) are HARDENED. Can't buy them at, say Lowes or Home Depot. All I needed was 6 of each. Finally went to GRAINGER, but had to buy 50 of each. 50 bolts 50 nuts. 1/2-24 threads x 1.5 inches long if I recall correctly. 100 bucks. All I can say is, if the other jacks fail, I got the hardware.
So: yes, the jack is heavy. I put a floor jack under it to lower it down...used the jack to put the new one up. Works fine. Just last week, I noticed one of the crimps on a hose to another jack was leaking. 13 years...these things to rot out. 7 ft hose with fittings, assembled while I wait (10 mints) ANOTHER 100 bucks. It never stops.
