notnuf
Jul 18, 2015Explorer
Leaking Water Behind Water Panel
I have a Coachmen 2007 Mirada. Add water to fresh water tanks. Eventually the water pump stops but as soon as you turn on faucets you start loosing pressure. A lot of leaking behind exterior water panel. Trying to disconnect the outside shower connection on the water panel. Seems to be only done from the back side of the panel. Any advice would be appreciated.
