MagillaGorilla
Jul 22, 2015Explorer
Leaking Water while boondocking
Today is our first time boondocking with our new MH. I filled the fresh water tank to the top then we headed to our boondock spot at the beach.
When I turned the pump on water came out of the "fresh water fill" inlet. This was due to the diverter valve being in the wrong position. When I switch the position water just leaks out of the fresh water fill inlet. If I leave it in this position I can use the pump and build pressure BUT water still pours out (slowly). If I change the position of the valve is stops pouring out UNTIL I turn the pump on. Then it is just pumping it out.
Is it possible that I have just over filled the fresh water tank and that's why its leaking while in the closed position?
Camper = 2005 Holiday Rambler Admiral.
