Chuck_Sorensen
Aug 23, 2013Explorer
Hi -
My leaks were due to the top glass not being bonded to the window frames. Entire front vertical section and around to half way back on the top. Continuous open space; I could push on the glass and see outside through the crack. Both rear windows. I needed to remove the one piece inside rubber "seals" around the windows to see the frame to glass interface.
Smaller leaks and I would have given RTV a try.
Best of luck to you; dry is good.
Chuck Sorensen
Buellton, California
2012 PW Excel TS
Chuck Sorensen
2012 PW Excel TS
38,782 PostsLatest Activity: Sep 02, 2026
