turbojimmy
Oct 13, 2014Explorer
rockhillmanor wrote:
They just cut off both pipes coming from the black and gray and installed a whole new Y assembly. You can pick the Y assembly up at any camping store or dealership. I installs just like a residential fix under a sink with a rubber sleeve and hose clamps.
That way you would have the correct fitting for the sewer hose too.
Yeah, that's probably the best way to do it. I see different kinds of "y"s online that would work.
I've also seen the twist-on repair valves, too. But, I'd need an adapter to go from the Thetford to the Valterra, then twist on the repair valve. I think it would stick out too far by the time I was done with all of that.
38,782 PostsLatest Activity: Sep 10, 2026
