I hava a 2006 Fleetwood with 30,000 miles.Ive been told the rear stableizer bushings are bad and need to be replaced, thats why it is leaning to the pass side.Any info would be helpful.Thanks
How bad is the lean? Is your driveway perfectly level? I would take it to a level parking lot and measure the ride height from left to right front to back and see if it is within spec. If not then get all 4 corners weighed and if you have more weight on one side shift some to the other side, if not then beef up the leaf springs.
