josianna's avatar
josianna
learning about rving
I am hoping to do some ring in the near future and would like to have some suggestions. I am a senior single female and come with two pups. When younger up to four years ago tenting was my way to go and now that I have a cap things are a changing. Canada 's west is where home is and would love to explore and perhaps live in for a time while I search for a new home. The type of motorhome would probably be a class c. any and all help would be appreciated. Thanks
  • jdc1's avatar
    jdc1
    Explorer II
    Like DrewE said......and, you might need a (toad) a car to be towed for commuting, unless you get something small enough to get around. Find a friend that has a Class C and see if you can stay in it a couple days. Cheaper than renting one.
  • Owning, maintaining and operating an RV requires some physical agility and effort/strength. You will need to "hunker down" and connect a drain hose to empty black gray water tanks and need to fill your fresh water tank. You will need to deploy and store your awning, fill your gas tank, and check your engine oil. If you intend to sleep in an overhead bed, it requires ladder climbing and some effort getting into and out of bed safely. There is a "house battery" and an RV generator that need maintenance. At 82, things that were once easy have become difficult for me but still doable. There are a number of technical and maintenance things that others can do for you, for a price. Buying a new or a used RV is tricky and you can make costly mistakes unless you equip yourself with knowledge or get help deciding what kind of RV you want, features, age if used, brand name, model name/size/floor plan, etc.,
    Consider total cost of ownership and use: Initial price, financing charges, depreciation, insurance and emergency road service, DMV registration, maintenance services, fuel cost, RV camp space rental, incidentals, etc. Not meant to discourage you but to make you aware if you are not already aware. Consider a used Class B like a "Road Trek". Easier to drive, more expensive than Class C, usable as a get-around vehicle and camper. Good Luck!
  • A few general suggestions:
    1. Consider renting a motorhome for a few days or a week before purchasing one. You'll learn a fair bit about what it's like to use and drive one, and be better able to evaluate what features, floorplans, etc. would work for you, and be a leg up on understanding the systems of an RV.
    2. I would generally not recommend buying new for your first RV. I'm not sure I'd buy new for any RV, personally, since the initial depreciation is pretty high and more often than there should be there are a bunch of--hopefully minor--initial defects to work through with the dealer/manufacturer. Let someone else take the financial hit and annoyance.
    3. When it comes time to look at specific models to maybe buy, I suggest taking time to do a "dry run" of as many daily activities as you can--preferably physically, but at least in your mind. Go through the motions of dressing or undressing, cooking a meal, watching TV, reading a book, using the bathroom and shower, etc., and give thought to where things might be stored and whether you'll be forever bumping into a cabinet and so forth. Is there a good place for a trash can? a laundry bag or basket? Can you access the bathroom or fridge after pulling off the road without needing to deploy a slide? Is there room for your cutlery, your dishes, your coffee percolator, and your saucepans?
  • Sorry I have sleep apnea and so use a cpap machine which needs electricity to run. Tenting was fun and so affordable but time does move on. Nowadays I am thinking that it would be safer to be in a vehicle especially at night with my age. Bathrooms are good.
    What is a "cap"? I don't have any specific answers for you (there are lots of websites that do.. search for "beginning RV tips" and you'll find lots of videos and websites offering advice).
    But I'm wondering what a "cap" is and why it made you stop tent camping, since that's something that people here may have specific advice for.
  • Determine your CAP’s amp hour use. With adequate batteries and solar for recharging, it’s no problem.
  • Rent! It will help you decide on the floor plan, length etc. for a purchase. If you plan to pull a toad, watch the MH’s max tow weight.
