time2roll
Sep 07, 2017Nomad
I don't buy it. Caliper can seize up either way from non-use.
Does the parking brake really actuate the disk or a drum brake?
If you don't use it much I recommend lubing the slide areas when you change brake fluid every two years.
My test is to put transmission in neutral. If it starts to roll set the parking brake. After you verify the parking brake is holding the vehicle then put transmission into park.
38,774 PostsLatest Activity: Apr 26, 2026
