ScottG
Sep 07, 2017Nomad
klutchdust wrote:ScottG wrote:klutchdust wrote:time2roll wrote:
I don't buy it. Caliper can seize up either way from non-use.
Does the parking brake really actuate the disk or a drum brake?
If you don't use it much I recommend lubing the slide areas when you change brake fluid every two years.
My test is to put transmission in neutral. If it starts to roll set the parking brake. After you verify the parking brake is holding the vehicle then put transmission into park.
I have wrenched my entire life. I have changed brake fluid only when the repair called for it, be it a broken line or whatever. My question is this,what has changed in the brake fluid industry that some feel the need to replace their fluid. One of my vehicles i owned for over 25 years, it stopped just fine and had no indication of fluid losing it's ability to work properly.
Recently a friend told me the quick lube stores are recommending it to customers.
It has also been a good idea to change it regularly because moisture builds up in it and makes it less effective and rots things like wheel cylinders and all the other iron components. That same moisture also kills anti-lock components. Changing fluid is cheap insurance against expensive repairs.
Personally, I can feel a difference in the initial bite of brakes and stronger pedal after really ancient fluid has been changed.
Thats good information. i didn't take into account the new components in these systems.
Some of them you even have to hook up a scan tool and actuate the anti-lock servo's in order to bleed them. :R
38,774 PostsLatest Activity: Apr 26, 2026
