Sam_Spade
Sep 07, 2017Explorer
ScottG wrote:
It has also been a good idea to change it regularly because moisture builds up in it
Old wives tale. Sorry but it IS.
If the sealed system is compromised to the point that water (even moist air) can get IN....then the brake fluid will also leak OUT.
No leaks, no moisture infiltration.
The reason that shops "recommend" it is that it increases their margin.....especially if they can sell you other parts in the process......like new rotors to replace ones that are not bad.
38,774 PostsLatest Activity: Apr 26, 2026
