Matt_Colie
Sep 10, 2017Explorer II
klutchdust wrote:
I have wrenched my entire life. I have changed brake fluid only when the repair called for it, be it a broken line or whatever. My question is this,what has changed in the brake fluid industry that some feel the need to replace their fluid. One of my vehicles i owned for over 25 years, it stopped just fine and had no indication of fluid losing it's ability to work properly.
Recently a friend told me the quick lube stores are recommending it to customers.
OK Klutchdust,
I can tell you what changed. Vehicles changed. You have had the same vehicle for 25 years. Before that vehicle was built, the life of a passcar or light truck brake system was maybe 5 years (I one was lucky). The typical passcar was scrapped at something around 100K and a rare one made it to 15years. (They only had odo that went about that far.)
Not counting the antique coach which is a choice, the two passcars in the family are both seniors. The "new" one is 16yo and still under 200K. Mine is 22yo and is way over 200k (the odo broke 5 years back).
Brake fluids DOT 3 & 4 are both HIGHLY HYDROSCOPIC. It will soak up all the water it can get. A typical disk/drum system can even let some (a molecule at a time - but it adds up) in through the seals at the pistons. In long term testing, we found brake fluid with over 4% moisture in systems that had no other deficiency and had been properly maintained. There was still no corrosion to be found anywhere in the system.
The problem then gets to be the fact that the water depresses the boiling point. With DOT 3 fluid, this can get bad real fast.
What about DOT 5??
That has a very high boiling point and does not absorb any moisture.
Sounds good - Right? Problem:
Moisture can still come in through the seals. But, now it is not absorbed by the brake fluid. It can pool in the bottom of cylinders and corrode them.
As you can see, it is your call. I have access to an instrument that reads the moisture content of the brake fluid and if I find any, I flush the system.
Matt - retired Detroit engineer
38,774 PostsLatest Activity: Apr 26, 2026
