I just purchased a RoadMaster Light Kit #155 to install in our Jeep Liberty dingy, can I use a LED bulb that is said to replace the 1157. The RoadMaster Kit uses one bulb for brakes, tail and turn si...
Anthony, I doubt the problem was low voltage. Usually LEDs are fine with low voltage, but you often need to limit the current on the circuit by adding a resistor. http://led.linear1.org/why-do-i-need-a-resistor-with-an-led/. But as long as those relays work the circuit, your in good shape!
