busyguy
Sep 16, 2017Explorer
LED Head lights
I have a 2 headlight system on my coach. 2000 Harney and am thinking of changing the headlights to LED. Lots of them available and lots of price's. Has anyone done this and if so which lights did you...
FIRE UP wrote:rhagfo wrote:
I very much dislike LED headlights as they don't aim well, and tend to blind on coming drivers.
Best head lights I ever had was a set of Lucas driving lights, would work in conjunction with high beams, would light a 1/4 mile down the road, but just the road, no spread to other lanes,
That's because you're looking at either JUNK LED headlights and, that coupled with the fact that they're not aimed correctly. There are lots of junk LED headlights out on the market. Anybody and their brother have gotten into manufacturing LED headlights in the last couple of years. A very large percentage of them are cheaply manufactured and, do not have the technology built into them that creates a well thought out LED headlight.
Jeep, as in the Wrangler version, came out with them from the factory for the year 2017. Those are some seriously bright and, well engineered headlights. They have the correct CUT OFF that is engineered into Halogens, HIDs, and others.
That "Cut-off" is what's vitally important when you have a BRIGHT headlight and, it's AIMED PROPERLY. When the headlight is aimed properly, it can be ultra bright (within legal limits) yet, not one oncoming driver will be offended.
I have a set of those '17 OEM LED headlights installed in our '15 Jeep JKUR. Those simply DESTROY the original Halogens yet, I've not been "Flashed" by any oncoming drivers, not even once, since I did the install of them, several months ago.
Anyway, to the OP or, anyone else looking for a potential LED headlight upgrade, do your due-diligence in investigation before making your choice. This is by far, one of the times that, the more you pay, the WAY HIGHER quality you'll get. The $100 or even most $200 sets of LED headlights are for the most part, pure JUNK. They're not bright, have what's called "Dead spots" in the projection of light in that, there's spots that are not covered by light and, in many cases, have little to no actual cutoff so, yes, with those you can offend oncoming drivers, just because you think you need to aim them higher, just to get light on the road. But, you're in fact, too high in the aim.
So, if you want good LED light, you're gonna have to pay.
Scott
