dtgunner7ExplorerJul 10, 2015LED marker lightsTried to replace #67 bulbs with led bulbs, listed as 1156. They are single post bases, so can't turn around. Used a small 12v battery to check out and they worked. Any ideas...
enblethenNomadJul 10, 2015Check the polarity first.The center pin should be 12 volts DC positive. The shell should be the negative.
Related Contentmarker lights to led marker lightsLED Side Marker LightsLED's for marker lightsTowing lights issueAre LED Marker Lights Better Than Incandescent Markers?
