truckcamperonmy
Mar 27, 2014Explorer
Are LED Marker Lights Better Than Incandescent Markers?
My 2011 Arctic Fox came with LED markers…I think that may have been the first year their exterior lights were standard LED? Anyway, I just recently had one of the front Amber LED markers fail and a lens cover came off one of the two side amber LED markers that is still working. I swapped lenses to protect the working LED and I'm waiting for two fully sealed LED markers from etrailer.com to arrive that another TC'er recommended here on the forum. Clicky
I also have two failing LED markers on the rear of the camper…one dimmer than the other, but on their last legs.
This made me think, maybe incandescent marker lights are better? When they burn out (in theory more often than LED) all you have to do is pop off the lens and slam another cheap little bulb in. Spare bulbs take almost no room compared to a full LED replacement marker and bulbs are more readily available and cheaper. I haven't replaced the LED yet, but I'll have to unscrew it, rewire it, and re-caulk it…what a pain!
Anyone out there switch their LED markers over to incandescent? Sounds crazy, right?!?! I'm all for conserving batteries by using LED for all interior and outside entryway/awning lights (I've switched all mine over to LED, but maybe old school is the way to go for markers that are only on when the truck is running?) LED tail/stop/turn lights are much more visible than bulb-style. Although, one of my Bargman LED tail/stop/turn lights died too and I had to replace that too. Not the cheapest lights either.
Although I already made the plunge and bought the amber marker LED lights, I haven't pulled the trigger on the red marker light replacements. What would you do…replace burned out markers with LED or incandescent?
