Tried to replace #67 bulbs with led bulbs, listed as 1156. They are single post bases, so can't turn around. Used a small 12v battery to check out and they worked. Any ideas...
Reversed polarity. When an LED light does NOT work when installing, the 12 volt positive must be on the correct positive input to the Light assbly. Doug
