rgatijnet1
Jan 15, 2014Explorer III
Many of the RV have had problems with leaking clearance lights and water damage in the front and rear caps. Going to a SEALED LED light can eliminate that problem. Since the bulbs are sealed, the entire fixture can be set in sealant with no worry about water leaking in through the lens and into the coach.
Look for light fixtures that provide plenty of brightness(the more LED's the better) which are not necessarily the least expensive.
38,777 PostsLatest Activity: May 20, 2026
