wny_pat1
Jan 15, 2014Explorer
Bumpyroad wrote:And I have had to replace many clearance light bulbs, both front and rear, over the years. But I have only owned older rvs, but my experience also includes many tractor trailers, both new and old. The last time I replaced them on my current coach, I replaced all of them with sealed Grote LED units. Have not had to replace any of them in well over a year now.wny_pat wrote:2oldman wrote:Truck Lite's warranty - "Truck-Lite extends a Limited Lifetime Warranty to the original purchaser that the Truck-Lite Sealed LED lamp is free from defects in workmanship and/or materials only. Truck-Lite will replace any Sealed LED Lamp to the original consumer/purchaser, if the lamp fails due to defects in workmanship and/or materials only." Other LED do not offer that kind of warranty.Bumpyroad wrote:Because they look cool, and some of us have the money.
why bother and waste the money?
bumpy
I can not remember EVER having to replace a clearance or other similar light on any of my RVs, and I believe tail/stop lights have had to be replaced quite seldom. but if one wants to invest $$$$ in expensive bulbs/housings to get 20% more mileage, go for it.
bumpy
As to gaining horsepower or mpg, I suppose there is some gain, enought to be measured. You could test by removing your alternator and trying to run it on you cars engine while connected to a dynamometer while it is under draw from all the lights on the motorhome. Remove and replace all the bulbs and replace them with LEDs and see how much less force is required to run the alternator then. Just adding a rear tag axle on a motorhome takes extra horsepower from the engine. In fact, the extra drive axle on a Class 8 tractor takes 25 horsepower from the engine. And that horsepower requires fuel. A alternator which has higher current draw also requires extra horsepower from the engine. When you are only getting 10 mpg to begin with, every extra little thing helps, but is not greatly noticed!
38,777 PostsLatest Activity: May 20, 2026
