After removing our old analog TV, I had the inside of the TV space finished and a door prepared to close the space just like our other cabinets in the RV. However, this door had a full-length piano hinge at the top. A hole cut in the door for cables to pass through. The TV was mounted directly to the door (4 of the 5mm screws hold it securely to the cabinet door). This makes for a very solid assembly. The cabinet door can be opened and swings up 90 degrees to allow access to the space inside the cabinet. I did a prototype of this and had the professionals at Winnebago in Forest City prepare the actual door on their computer controlled equipment. Result looks just great! They also added a thin sheet of steel on the inside of the cabinet door to support the weight of the TV (their door panel was thinner than the 1/2" ply I used for the prototype). This has proven to be very functional for us especially since we never need to adjust the angle of the TV once it was set.
