- IvylogExplorer IIIWith only one post I can’t tell your abilities on testing??? Are you saying when you turn the key on there isn’t 12V at the alternator or the alternator does not work???
- theoldwizard1Explorer II
MrWizard wrote:
... excitation of the alternator field winding come from the voltage regular and / or the engine CPU
Depends on the "vintage" of the charging system !
On older charging systems, the field was "excited" through the key and the "idiot" light. If there idiot light had failed, the alternator would not get excited when you started the engine. It may or may not "self excite" after the engine was running.
- wolfe10ExplorerIf this is a DUVAC alternator, these are the connections:
B+ to battery isolator (large-gauge wire)
Ground-- may be separate wire or may ground through engine (metal to metal)
Ignition hot small terminal/excite terminal-- gets power from any ignition hot connection in engine compartment
Sense small terminal-- small gauge wire connected anywhere on the "battery side of the battery isolator".
The last two are small gauge wires and can break. Pretty easy to check with a digital voltmeter. - MrWizardModeratorDo you mean the alternator is not charging the battery
Power flow is from battery Too ignition
And from alternator to battery
38,782 PostsLatest Activity: Sep 19, 2026
