bobndot
Jan 02, 2023Explorer III
John, would a portable Rayzar work for you ? You can view them on youtube or the websites video link.
You could place it inside a window near the tv you mount.
Amazon sells it, if it’s not any good, return it .
It might be an easier option if reception is decent.
When many rv manufacturers have a ‘prewired’ tv option, they place a piece of 10x10 plywood inside the wall at a location to be able to view from bed or swing-out for a dinette view . Its a backing to screw into for the tv mount. Knock on the wall , to locate it.
Once you find it and mount the tv, i would add a web strap with a velcro closure across the screen to secure it for travel. I have seen tv’s rip out of walls bouncing down the road.
https://www.opticsplanet.com/winegard-rv-rz85-rayzar-portable-indoor-antenna.html?sscid=11k7_1j9qx
If you choose a permanent cable box in a wall-mount, i had to use right-angel connectors bc the rv wall was to thin for the coax to bend attaching it to the wall plate.
