dougrainer
Oct 06, 2015Nomad
You do not state what brand Jacks. Fleetwood used Powergear back then. The jack pad is bolted on from the bottom. Can you remove the jack pad and shim it DOWN a little bit using a slightly longer pad mounting bolt and washers? Doug
38,766 PostsLatest Activity: Jan 10, 2026
