coolmom42's avatar
coolmom42
Explorer II
Nov 13, 2020
Leveling a Class C?
If the rear of a Class C needs to be raised to level up when parked, is it necessary to raise all the wheels? Or is it adequate to get 1 tire on each side to the right level?
So far all my sites have been very close to level, but that won't last, for sure.
  • tobydad wrote:
    If you are staying for a short time (such as a weekend) I think levelers under one of the duals in the rear would be OK, but if you are staying longer, then levelers under both tires would be best. I use the ramp type levelers.
    This.
  • We always support both tires of our duals equally. I think that is best practice.
  • It is always best to put both tires up on the levelers,thus evening up the load on the tires and the wheels.
    I found that The Tri leveler work very well.
  • If you need to level the rears on a Class C be sure to support both tires on whichever side you are lifting. There is no problem placing blocks or other lifting devices under 2 or even all 4 rear wheels so long as both on each side are supported. In seven years I have never had to go higher than 2 yellow leggo blocks high and properly centered your tires are not going anywhere.
    :C
  • coolmom42 wrote:
    bobndot wrote:
    You need to keep the rear tires on the ground due to the parking brake holds the rv from rolling. Its ok to use the rears just don't over do it and stress the jacks.
    Jacks? What jacks? I don't have leveling jacks and they are not really common on smaller C's as best as I can tell.
    And if the rear tires have to stay on the ground, and the rear is too low, how can a person level up?
    Not clear to me what you are saying here.
    I thought you had jacks on your rig. They have become popular on shorter class C's, FR 24 ft models have them .
    Its ok for you to just place a board or two under the rear wheels. For added safety block the front wheels .
  • If you are staying for a short time (such as a weekend) I think levelers under one of the duals in the rear would be OK, but if you are staying longer, then levelers under both tires would be best. I use the ramp type levelers.
  • You need to keep the rear tires on the ground due to the parking brake holds the rv from rolling. Its ok to use the rears just don't over do it and stress the jacks.
