wildmanbaker wrote:
mssmith, are you sure it was deleted? I sometimes have a post disappear, only to find that I actually did not post it, bit deleted by mistake.
JetAonly, yes lucky, the only damage was the inside duals valve stems were sheared off, and the rear leveling jack mounding plates were bent. Some work with a press and large crescent wrenches make them good as new.
OK lets hope the OP can get his problems fixed.
It was deleted. I've argued back with the moderators before so I'm convinced they have me on "the list." Whenever I post something alarm bells go off and they go check to make sure all is safe.
