J-Rooster wrote:
You never want your back wheels off the ground the parking brake on the rear wheels is what holds the coach in place! Since your back wheels are already off the ground I would cut 2"X10"X 2'douglas fir planks and slide them under your back wheels then lower your jacks. Make sure the planks are under all tire tread. Then use a couple pieces of douglas fir beam to the height that they just slide under your rear jacks then lift the jacks just enough to level the coach.
X2
Have you located your fluid reservoir? Check the fluid level. Do you have any leaks in the system?
